Is 3,400 rpm's normal at 80 mph
2005 SCION XB
98,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
TROY FRENCH2
I was test driving this car and want to know if 3,400 rpm is normal at 80 mph? Not used to four speed automatic transmissions and just wanted to know if that sounds about right or if there is a shifting problem.
Nov 26, 2018 at 6:53 PM
  • 110,194 POSTS
That sounds normal. Just make sure there are no engine or other lights on, the transmission shifts smoothly, and it has been inspected. I always recommend having a car checked by a technician before buying it. That is no guarantee everything is perfect, but at least a good tech can spot typical problems.
Always remember the old saying. "Buyer Beware"
Take care and I wish you luck with the new car (if you get it).
Nov 26, 2018 at 6:59 PM
