In the winter is it okay to drive when the RPMs are above 1,000?
90,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
PAPET
  • 105 POSTS
During winter season here in Canada, when I first start my vehicle in the morning before going to work the RPMs go like in between 1,300 to 1,500 RPMs. And after 3 to 5 minutes of idling, the RPMs go down. My question is, is it okay to drive when the RPMs is above 1,000? During summer time, the RPMs goes under a 1,000 after 30 seconds. Thanks and hoping for your most appreciated reply.
Mar 7, 2021 at 8:42 PM
CARADIODOC
  • 34,413 POSTS
That's commonly called "idle flare-up". It's done to help the engine warm up faster and to insure sufficient oil flow when it's cold. I have a 2014 Ram 1500 that does the same thing, but I'm in the habit of letting it warm up at least three or four minutes every day. Pistons don't fit properly until they reach normal temperature, so most engine wear takes place in those first few minutes. That's why vehicles that are driven long distances every day can reach 300,00 to 500,000 miles and still be running fine while those that are driven only a few miles back and forth to work are worn out in as little as 100,000 miles.
It is okay to drive the van right away after starting, but the engine will appreciate a little time to get that oil flowing to the bearings and seals. You should find idle speed comes down to normal sooner when you shift into gear.
Mar 8, 2021 at 2:17 AM
PAPET
  • 105 POSTS
Thanks a lot for your most appreciated reply.
Mar 8, 2021 at 4:40 AM
CARADIODOC
  • 34,413 POSTS
Please come back to see us with your next question.
Mar 8, 2021 at 5:09 AM
