RPM
1,002,400 MILES
KIM HENDRICKS
I am always late, but yesterday I had to wait to get gas. I do not like to get below a fourth of a tank. After I got my gas it ran a little rough and the rpm's stayed at around two city driving.
What do I need to do?
Apr 19, 2017 at 10:07 PM
KIM HENDRICKS
The mileage is a hundred thousand, sorry.
Apr 19, 2017 at 10:08 PM
HMAC300
  • 48,601 POSTS
scan for codes and check for a vacuum leak like hoses off/broken etc. you might also try cleaning throttle plate and IAC hole with choke cleaner clean plate on both sides.
Apr 19, 2017 at 10:59 PM
STEVE W.
  • 15,419 POSTS
Also have the EVAP purge valve checked. If they stick open they can cause rough engine and even no-start problems after you fuel up.
Apr 21, 2017 at 6:29 PM
