Rpm Issue
99,000 MILES
PISTOL73
When I turn on the car and I step on the pedal down the rpm goes only to three revolution and goes down one while I am park on my driveway. Anyone have a solution?
Jan 29, 2017 at 6:04 AM
SATURNTECH9
  • 30,869 POSTS
So does it drive normal with no warning lights on the dash? It sounds like a rev limiter that is built into software into the computer.
Jan 29, 2017 at 7:49 AM
PISTOL73
No indication on and that is what I was thinking that it was the issue. Thanks for answering my question.
Jan 29, 2017 at 7:50 AM
MARCUSCRO
My 300m is hesitant to start. Usually, tries turning over but only turns over every so often. Sometimes it'll start weak and die off instantly. While driving, if I take my car past 2500 rpm it acts like a rev limiter. There is a rev limiter in my car. But it's set to 6k rpm.
Feb 1, 2017 at 9:12 PM (Merged)
  • 110,248 POSTS
Has the check engine light come on? Have you checked fuel pump pressure? Have you checked for a plugged catalytic converter? When was the last tune up?
