not starting
ROVER
1MATT1
HI i have a rover 200 with 2.0lturbo tom cat engine which i fitted,
I have spliced the looms together and running off of the 2.0l e.c.u.
The engine has fuel,spark and compression is perfect, However the car starts but imedietly stalls,
The car runs all the time if i spray either down the inlet which signals fuel problem, I have removed the injectors and whilst cranking they work fine, Re-fitted them and used the power probe, When the ignition is off all 5 wires to the injectors are earth and all switch live when ignition is on. Ive looked in trouble shooting in the technical data book and it read about bad earth under bonnet so e.c.u would only have a short voltage, So i cleaned the terminals and also used a jump lead from earth to e.c.u, As then i know that the e.c.u shud have the correct voltage, But it still wont stay running any ideas?
Jul 1, 2010 at 6:52 AM
DAVE H
  • 13,383 POSTS
sounds like the immobolizer system is killing fuel injectors after cranking ..
Jul 1, 2010 at 11:20 AM
