1999 Other Rover Models petrol problems
1999 ROVER
101,000 MILES • 4 CYL • FWD • MANUAL
STIGMA53
i have a rover 400 it wont start the petrol doesnt seem to be gettin through ive had the petrol pump tested and is workin fine i cant find any blockages but the car still wont start what could it be ?
Sep 8, 2009 at 11:29 PM
DAVE H
  • 13,383 POSTS
check for spark and fuel at spark plugs .. check the fuel pump fuse and use a voltmeter to check you are getting power to the pump ...also check the imoboliser is coming off !!
Sep 9, 2009 at 10:06 PM
STIGMA53
there isnt any petrol gettin to the spark plugs the petrol pump doesnt seem to pumpin the petrol through but we have had it tested and was told its workin ok we checked the petrol pump fuse and that is ok to and the imobiliser is workin ok to but if we put petrol down the bores the car will start
Sep 11, 2009 at 12:05 AM
STIGMA53
[quote:5ed836c3da="Dave H"]check for spark and fuel at spark plugs .. check the fuel pump fuse and use a voltmeter to check you are getting power to the pump ...also check the imoboliser is coming off !![/quote:5ed836c3da] there isnt any petrol gettin through to the spark plugs the pump doesnt seem to be pumpin it through but we have had it tested and was told it was workin ok the petrol pump fuse and imobiliser are both ok to but if we put petrol down the bores the car will start
Sep 11, 2009 at 12:10 AM
DAVE H
  • 13,383 POSTS
check the inertia fuel cut off switch is not tripped .. .. it is located behind the centre console (gear lever/radio) on most models !!
Sep 11, 2009 at 9:52 PM
