1999 Other Rover Models coolant tank
1999 ROVER
MATT1978
Engine Cooling problem
1999 Other Rover Models Front Wheel Drive Manual 45000 miles
whilst driving i noticed steam escaping from the coolant tank cap, the level was low so i topped up with a water/anti-freeze mix. i then had a drive around the block(10 mins ) when i heard a sound similair to a kettle boiling. when i opened the bonnet brown water and steam was escaping from the cap again. any suggestions as to what the problem may be, is this cheap to repair.
My car is a rover 200 1.6
Tanks
Apr 26, 2009 at 11:13 PM
DAVE H
  • 13,383 POSTS
Have the engine compression tested .. suspect headgasket failure ... a common fault on this vehicle !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_597.png
Apr 28, 2009 at 12:41 AM
