1998 Other Rover Models Ignition Coil
1998 ROVER
PWILSON33
Engine Mechanical problem
1998 Other Rover Models Manual 61000 miles
My car won't start, when the key is turn the car cranks but does not start.
I have replaced the spark plugs, and performed a test for the ignition coil that was negative.
Therefore I believe that the ignition coil has gone, could you suggest anything else that may be indicated?
I would also like to enquire as to how replace an ignition coil in a Rover 200 1.1 (R reg)?
Thank you
Mar 21, 2009 at 5:06 AM
DAVE H
  • 13,383 POSTS
I would replace the coil if you are not getting any spark on any of the plugs ..your next test would be to see if you are getting a pulsed signal to the coil .. replacing the coil is a simple bolt off unplug the wiring connecter hook up new one and bolt back on .. Hope this helps .. let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_343.png
Mar 21, 2009 at 7:16 AM
