1998 Other Rover Models Head gasket
1998 ROVER
45,000 MILES • 4 CYL • FWD • MANUAL
WARD5951
Does steel seal work in repairing head gaskets?. The coolant has a mayo deposit in thbe headser tank. It appears clear when released from the engine and rad. There is no coolant in the oil. Is there a product that could repair the gaket without splitting the engine?. I have a gasket set and head bolts but cant get at all the bolts and nuts to be able to remove the head. It is a Rover 216 DOHC engine.
Jan 20, 2009 at 7:07 PM
  • 31,937 POSTS
Hi there,
These quick fixes at best do a temp sealing job, but if the head is damaged or the gasket the pressures and heat generated internally of the engine will continue to damage components and further failure will result, also these chemical sealants also can clog radiators and cause further problems, my advice is fix it properly and don't relay on chemical fixes.
mark (mhpautos)
Jan 20, 2009 at 7:20 PM
