2003 Rover 75 radiator fan
55,000 MILES • 6 CYL • 2WD • MANUAL
TOPCAT1960
my radiator fan seems to be running nearly all the time and i dont have any control over the heater plus the temp gauge on the dashboard says that it is permanatly -22 can you help ?
Nov 22, 2009 at 3:52 AM
DAVE H
  • 13,383 POSTS
start by checking your coolant level is correct !! the temp display you refer to,is for outside temp and the sensor is probably faulty and needs replacing
Nov 23, 2009 at 9:14 PM
