2001 Rover 75 non starter
91,000 MILES • 6 CYL • FWD • AUTOMATIC
HANDYJACKDANIELS
my rover 75 cranks over but will not fire up. The previous owner had a diagnostics check done that showed camshaft sensor- no signal and vis balance valve always closed.
I changed the sensor, no different.
I had my own diagnostics check done and it again showed cam and crank sensor no signal( dtc p0340 and p0335), plus it showed ' security code not received (p1666) and immobilisation ecu fault code 0x0f/ random code tolerance increased and bad key identification.
both cam and crank sensors have been replaced with new, so is it the immobiliser ecu, engine ecu, or just a dodgy key? If so how can i rectify?? Help!!!!!
Nov 5, 2009 at 8:49 PM
DAVE H
  • 13,383 POSTS
suspect a key/immoboliser fault .. the car and key may need reprograming back together using a rover diagnostic computer system !
Nov 7, 2009 at 11:19 PM
