1999 Rover 75 car engine bonnet
RON SALISBURY
1999 Rover 75 6 cyl Two Wheel Drive Automatic
I need to open the engine bonnet or gain access into the engine compartment as the bonnet cables are inoperative. The bonnet is closed.
I suspect that the cable pull connector has pulled off the bodywork making it impossible to open the bonnet from inside the car.
Many thanks,
ER Salisbury
Sep 16, 2009 at 1:34 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
We don't have a lot of information on Rovers at the moment, so what i would suggest is to take the car to a mechanic and get it up on a hoist, or jack it up and remove any splash trays fitted, you may be able to reach up from under the car with a screwdriver and trip the lock that way, i have done this on a few models over the years with this problem, try this first.
mark (mhpautos)
Sep 16, 2009 at 12:16 PM
