2000 Rover 45 5th gear popping out
2000 ROVER 45
WIZARDOFWOZ
2000 Rover 45 Manual 50000 miles
my w reg rover 45 keeps popping out of gear. what is the most likely problem?
Jun 11, 2010 at 11:29 PM
  • 31,937 POSTS
hi there,
weak or broken detente spring in selector, worn selector hub, transmission loose on engine, if it tends to pop out under over run, i.e. throttle off down a slight down grade, normally a worn of defective synchro hub in the transmission.
Mark (mhpautos)
Jun 11, 2010 at 11:40 PM
