1998 Rover 4 Series Rover 416 post rocker/valve gasket chan
81,000 MILES • 4 CYL • FWD • MANUAL
DANHARPER
hi
just bought an R reg Rover 416 sli - all looks in great condition (although I know the k-series is good at popping its head gasket so I put sealant in anyhow!) - 81k
changed the rocker/valve gasket as oil was leaking (it was in a bad way when I opened it - cracked n snapped
disconnected battery -'ve and 2 hose inlets + leads from dist cap to sparks to get it off
put the new one on with sealant and re-connected all (right leads right places)
now it won't start
it is either the immobiliser or something else.... don't have the manual security key as second hand car, tried taking battery out of fob, then open close 4/5 times then starting
nothing
HELP!!!
May 10, 2010 at 10:57 AM
DAVE H
  • 13,383 POSTS
you need to have the vehicle plugged into a diagnostic computer to reset the alarm/immo .. or find a dealer who can supply the 4 digit bypass code using the VIN number
May 10, 2010 at 8:45 PM
