1998 Rover 4 Series BRAKING SYSTEM SERVO VACUUM NON RETURN
1998 ROVER 4 SERIES
GEOFF SMITH
Brakes problem
1998 Rover 4 Series 4 cyl Two Wheel Drive Manual
THERE WAS A LEAK IN THE CONNECTOR TO THE VALVE WHICH HAS BEEN REPAIRED. THERE STILL SOUNDS TO BE AN AIR LEAK UPON REPEATED APPLICATION OF THE BRAKE ALTHOUGH NOTHING CAN BE SEEN.
IS IT POSSIBLE THAT THE VALVE CAN BE DAMAGED DUE TO AIR SUCKING IN THROUGH THE ORIGINAL LEAK?
WHERE CAN A REPLACEMENT BE BOUGHT?
Oct 4, 2009 at 8:55 AM
