1997 Rover 4 Series engine not starting
1997 ROVER 4 SERIES
DEBSCARISBROKE
Engine Mechanical problem
1997 Rover 4 Series 4 cyl Two Wheel Drive Manual
hi, i have had problems with starting my rover 420sdi. we have changed the glow plugs and put a new battery on, it is turning over but not firing up, can you help?
Jan 2, 2010 at 12:21 AM
Crank and no start condition,do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 2, 2010 at 6:12 PM
DAVE H
  • 13,384 POSTS
Does the glow plug light on the dash display light up at all ? ...is the check engine light showing ? (orange engine light) ..start by locking and unlocking doors with remote keyfob then trying to start vehicle ... the immoboliser needs resetting this way after battery replacement !!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_941.png
Jan 3, 2010 at 12:57 AM
