2002 Rover 25 high revs
585,000 MILES • 4 CYL • FWD • MANUAL
SHEFFWEDFAN
  • 7 POSTS
my rover 25 starts ups and idles at 1100 rpm as it should but as the engine gets warm my rev counter rises and starts to idle at 1500 rpm but engine is not racing does this mean that my idle air control valve is faulty thanks
Aug 19, 2009 at 4:33 AM
DOCFIXIT
  • 18,828 POSTS
Maybe or engine coolant temp sensor
Aug 19, 2009 at 4:58 AM
SHEFFWEDFAN
  • 7 POSTS
ive replaced the cts
Aug 19, 2009 at 5:36 AM
DOCFIXIT
  • 18,828 POSTS
Try cleaning IAC and passageways. check for vacuum leaks also clean throttle body maybe carbon on plate
Aug 19, 2009 at 6:37 AM
SHEFFWEDFAN
  • 7 POSTS
ive try cleaning the iacv but a sealed unit,cleaned the tb and ive tried spraying wd40 on engine for leaks i think i can hear a leak but not sure if this is normal
Aug 20, 2009 at 2:11 AM
DOCFIXIT
  • 18,828 POSTS
For vacuum leak use carb cleaner when it hits leak idlewill change.
Aug 20, 2009 at 2:24 AM
SHEFFWEDFAN
  • 7 POSTS
where do i spray the carb cleaner to find leak,if there is no air leak is the iacv at fault
Aug 20, 2009 at 4:17 AM
DOCFIXIT
  • 18,828 POSTS
Try unpluging IAC and repluging can you hear motor run? I don't have acess to Rover info but there should be test proceedures like Ohm checks.
Aug 20, 2009 at 4:30 AM
SHEFFWEDFAN
  • 7 POSTS
when i turn the engine off i can hear the motor on the iacv working but how far should the plunger move,when i tried cleaning and switched the igniton on i saw the plunger move
Aug 20, 2009 at 4:43 AM
DOCFIXIT
  • 18,828 POSTS
Could try an experiment remove IAC and plug off airway. Start see if it still idles at 1500
Aug 20, 2009 at 5:02 AM
SHEFFWEDFAN
  • 7 POSTS
ive tried removing the iacv and plugging up the airway but the car will not start unless someone is manually opening the butterfly vakve on throttle body i have changed the cts but is it possible that they supplied me with the wrong one
Aug 21, 2009 at 2:06 AM
DOCFIXIT
  • 18,828 POSTS
That tells me that air is not getting around throttle plate so IAC looks suspect.
Aug 21, 2009 at 2:17 AM
SHEFFWEDFAN
  • 7 POSTS
ive replaced the iacv with a secondhand one and still the same problem but i cant hear any air leaks now is it possible the lambda sensor is faulty
Aug 24, 2009 at 5:02 AM
DOCFIXIT
  • 18,828 POSTS
https://www.2carpros.com/forum/2002-rover-25-high-revs-vt337616.html
Check out this post almost same problem. Maybe you two should exchange notes
Aug 24, 2009 at 5:10 AM
