Electrical problem
2002 Rover 25 4 cyl Two Wheel Drive Manual
Hi,the window will not go right to the top it stops just as it reaches the seal at the top of the window and the motor starts to click I can lift the window into place without much effort but then the window will not come down without moving it slightly by hand,the door card has been removed and i have checked for anything simple,the bolts holding the motor were loose and have now been tightened up but this made no difference I suspect that the motor may be worn as it clicks or is it.
Please help as this is now driving me mad.
Cheers.
Cheers.
Sep 5, 2009 at 10:30 PM
