2002 Rover 25 coils
ENDING89
Engine Mechanical problem
2002 Rover 25 Two Wheel Drive Manual 74,000 miles
hi i have a rover 25 its a 1400 three door. i reasontly put a new set of coils and sparkplugs in as the coils had melted but after i put the new set in withing the first hour or so it happend again. i notticed that the block ware the coils sit was piping hot. their was recently a new bore exhaust put on the car but that was of an evo 8 could that possibly be the cause of whats wrong.
Oct 2, 2009 at 11:08 PM
DAVE H
  • 13,383 POSTS
the car must be running way too hot .. this is what is melting the coils ..
Oct 4, 2009 at 9:38 PM
ENDING99
[quote:4bc5dc9a43="Dave H"]the car must be running way too hot .. this is what is melting the coils ..[/quote:4bc5dc9a43]
ok thanks but what would be causing the block to over heat any ideas and the best way to fix it withought spending to much money preferably thanks
Oct 7, 2009 at 8:37 AM
DAVE H
  • 13,383 POSTS
start by checking oil level is correct and is good oil ... renew with a thicker grade oil if necassary .. check the coolant level is correct and use a good anti-freeze to aid cooling ... also check you are not getting fuel burning in the new bore exhaust manifold !!!
Oct 7, 2009 at 12:35 PM
ENDING99
[quote:55b83bcd75="Dave H"]start by checking oil level is correct and is good oil ... renew with a thicker grade oil if necassary .. check the coolant level is correct and use a good anti-freeze to aid cooling ... also check you are not getting fuel burning in the new bore exhaust manifold !!![/quote:55b83bcd75]
last question about the manifold if their is fuel in their what shout i do or would i be better just getting a new exhaust.
thanks for all your help
Oct 7, 2009 at 10:06 PM
DAVE H
  • 13,383 POSTS
you need to buy another exhaust (standard or big bore) that was made for the rover 25 series !!
Oct 8, 2009 at 8:50 PM
ENDING99
[quote:ddbc0dc8b5="Dave H"]you need to buy another exhaust (standard or big bore) that was made for the rover 25 series !![/quote:ddbc0dc8b5] ok thanks very much
Oct 8, 2009 at 11:32 PM
