2001 Rover 25 Car starts eratically
74,852 MILES • 4 CYL • FWD • MANUAL
MDUDUZI
Hie Guys.
My rover 25 1.6 had a head gasket changed (by me) and now starts eratically. It wont start when hot but at time will do. Starts well in the cold but struggles when the engine had a run. Runs smoothly and well but does not start. It had water in the oil but not oil in the coolant.
Took it apart and changed gastket, started after a few cranks to make sure everything was ok. The engine started and I switched it off to put everything back. It drives ok and wont stall but does have trouble starting emmediatley after that.
Jan 17, 2010 at 4:59 AM
DAVE H
  • 13,383 POSTS
check the timing is correct .. it may be one tooth off ?
Jan 30, 2010 at 9:18 PM
