2000 Rover 25 using too much coolant, radiator fan doesnt a
2000 ROVER 25
63,748 MILES • 4 CYL • FWD • MANUAL
GUMMYBEAR
head gasket replacement in june 2008 (including full head skim), no oil in water, or water in oil, using too much coolant, having to top up weekly full amount of water/coolant. Also radiator fan does not appear to be working. Could this be contributing to the problem? Thanks for your help.
Jan 1, 2010 at 3:33 AM
DAVE H
  • 13,384 POSTS
you need to discover why the fans are not working ? start by checking the fuse .. also check there are no coolant leaks !
Jan 4, 2010 at 7:29 PM
