1995 Rover 2 Series immobiliser
TINYPIE
Electrical problem
1995 Rover 2 Series 4 cyl Two Wheel Drive Manual
battery has been changed in key fog and directions followed to re set handset, immobiliser failing to turn off
Dec 31, 2009 at 2:27 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated Remove the keyfob battery for 2 minutes .. re-insert the battery and within 30 seconds press and hold the lock or unlock button .. you must do this within 30 seconds of re-inserting battery so do not try and replace the cover untill button is pressed and the keyfob is working .. There is a 4 digit bypass code listed in the vehicles handbook which you input using the drivers door lock and ignition key ..if you do not have the handbook a dealer should be able to supply the code if you supply the vehicles VIN number ...your only other option is to have the vehicle plugged into a diagnostic computer at a dealer and have the car and keyfob reprogrammed back together Hope this helps HAPPY NEW YEAR
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_929.png
Dec 31, 2009 at 9:12 AM
