1995 Rover 2 Series fuel pump not working
1995 ROVER 2 SERIES
140,000 MILES • 4 CYL • FWD • MANUAL
JAFFA
hi my fuel pump has stoped working it jus stoped but wen i put direct 12v to it the pump works but car still wont start also no power to pump but relay is working to run power to it how is the pump wired is it direct to fuse box or running from another place also how do i find it
Jan 2, 2009 at 4:54 PM
DAVE H
  • 13,384 POSTS
Hello Jaffa ... and thanks for the donation
The rover series of vehicles was not released here in the U.S.A. so unfortunately I do not have a wiring diagram to hand ... i have Emailed a friend in the U.K. for him to send me a wiring diagram .... until that arrives (time differences need to be taken into account ..haha..) let's do a few checks ..the rover series of vehicles has a fuel cut off switch under/behind the radio console bottom centre of dashboard... locate the switch press the button on the top to reset it .. then try and start the vehicle .. have you checked the fuse ... have you checked power is going to the relay .. you should have 12 volts @ pump with key ON .. the PCM (engine computer) grounds/earth's the pump for 5/10 seconds @ key ON to pressurise the system then cut's the pump until turning over the vehicle or engine running .. so if you put 12 volts direct to pump and turn over the engine it should fire up unless there is another fault ..
Jan 2, 2009 at 10:56 PM
