ROVER_DRIVER2009
Front Wheel Drive Automatic 89000 miles
please help me i drove my car home today and for some reason if i turn left or right i get a loud knocking noise please can you tell me what may be causing this problem
thank you
regards
gordon
Apr 16, 2009 at 11:30 AM
SQM
  • 6,383 POSTS
Since you hear the noise when you turn it is likely related to the tie rod ends.
Worn suspension components can also make loud noises, when they have weight loading and unloading.
Worn bushings can lead to excessive movement and metal on metal contact, which will lead to noise issue.
Take a look at this article, it covers the typical noise issue with the suspension:
https://www.2carpros.com/articles/popping-noise
Nov 15, 2021 at 10:30 AM
