Rough start even rougher idle
97,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ANNETTE DAWSON
My car struggles to start, sometimes twenty minutes, when it finally starts it runs dog rough, keeps cutting out.
Mar 15, 2019 at 8:40 PM
  • 110,248 POSTS
First, is the check engine light staying on when the engine is running? If it is, you need to scan the computer for diagnostic trouble codes that will help diagnose the problem.
Here is a quick video showing how it is done:
https://youtu.be/b2IJGfImVvw
Now, I realize most people don't own a scanner, but often times a parts store will do it for free or even rent one to you. With that in mind, that should be step one if the light is on.
Next, based on your description, I really question if there is an issue with fuel pressure. This can be the result of low or high pressure. Low pressure is usually the result of a bad pump or plugged fuel filter. If the pressure is too high, a fuel pressure regulator is usually the cause. Here is a link that shows how to check fuel pressure. Often times, if the pressure is too high, you will see black smoke from the exhaust when it starts, so pay attention to that.
One more thought is a plugged catalytic converter. Here are a couple links for you to look through. The first one discusses and describes symptoms of a plugged converter. The second one is how to test one. If this is the problem, it should have set the check engine light to come on and it should show up as a P0420 diagnostic code.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
If you can think of any other symptoms that may help, let me know. The things I identified seem to be most likely based on your description, but there are other things that can cause the problem.
Mar 16, 2019 at 2:24 PM
