Rough running fuel and carburetor related
280,000 MILES • V8 • 2WD • AUTOMATIC
BOBNOB1020
So here a story all about how my car got flip turned upside down. took my car in to have the transmission rebuilt. while they had it they noticed that one of the fuel lines was cracked, and being the cool people they are replaced it for me. when i got the car back the transmission ran great. when the car would run. wound up having to tow it back the the shop. they said it was a slightly kinked fuel line which they fixed. this time the car would run for a few minutes but would quickly start to run very rough and eventually stall I've tried a new carburetor rebuilt carburetor swapping out some slightly creaked fuel lines. haven't seemed to fix it.
TL:DR had shop replace some fuel lines and something seem to be happening with the carburetor how does this happen and how do i fix it.
Mar 23, 2019 at 12:21 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Since the fuel lines were worked on, my first suspect is that the fuel filter has plugged and restricting fuel to the engine. Thus, it starts, then slowly runs out of fuel and stalls the engine. Or, the pump is going bad. Have either of those been checked or replaced?
I need to know if this is a 4bbl or 2bbl carb. When it stalls, does it start right back up?
Here are the mixture adjustment procedure for the carb since it is new. I thought it may help. The two attached pictures are the specs for adjustment.
MIXTURE ADJUSTMENT PROCEDURE
Two methods of idle mixture adjustment are recommended. The "CO Meter Procedure" may be used on all except 6 cylinder engines if a suitable CO meter is available. The "Lean Drop Procedure" may be used on all models.
Air cleaner must be left in place and A/C control, if equipped, must be in off position during adjustments. Disconnect and plug vacuum hose at vacuum advance unit (all) and vacuum hose at EGR valve (Buick). On all Chevrolet models except Corvette and on Buick 6 cylinder models, disconnect fuel tank hose at vapor canister. On Buick V8 models, disconnect evaporative emission hose at air cleaner. On Corvette models, remove fuel filler cap.
CO Meter Procedure
1. Connect tachometer to engine following manufacturer's instructions. Start engine and run at fast idle until it reaches normal operating temperature.
2. Connect a suitable CO meter to vehicle following manufacturer's instructions.
3. Place transmission in drive manual transmission in neutral) and adjust curb idle speed to specifications by turning solenoid plunger screw.
4. Adjust idle mixture screws equally to obtain a CO reading at or below 0.3% at specified curb idle speed.
NOTE: If unable to obtain specified CO reading within adjustment range of limiter caps. cut off tang on each limiter cap, taking care not to damage mixture adjusting screws.
5. Stop engine. Turn each mixture adjusting screw in until lightly seated, then back screws out 4 turns.
6. Start engine and place transmission in drive (manual transmission in neutral).
7. Adjust curb idle speed to specifications by turning solenoid plunger screw.
8. Turn mixture adjusting screws clockwise (leaner) equally to obtain a CO reading at or below 0.3%, at specified curb idle speed, using solenoid plunger to adjust idle speed.
9. Disconnect wiring harness connector to solenoid and adjust low idle speed to specifications by turning throttle stop screw on carburetor.
10. Reconnect wire to solenoid and reconnect vacuum hoses to proper fittings. Install fuel filler cap on Corvette models.
Lean Drop Procedure
2. Stop engine. Cut off tang on each limiter cap, taking care not to damage mixture adjusting screws.
NOTE: If limiter caps have been removed, or if carburetor has been overhauled, turn each mixture screw in (clockwise) until lightly seated, then back screws Out 4 turns on 1 barrel carburetors, or 2 turns on 2 and 4 barrel carburetors.
3. Start engine and place transmission in drive (manual transmission in neutral).
Fig. 104 Lean Drop Adjustment Specifications
See Pic 1
Fig. 105 Lean Drop Adjustment Specifications
See Pic 2
4. Adjust idle speed to RPM specified for lean drop adjustment, Figs. 104 or 105:
a. On 2 and 4 barrel carburetors, turn solenoid plunger screw.
b. On 1 barrel carburetors, rotate solenoid assembly.
NOTE: Do not rotate solenoid more than 1 full turn without disconnecting wiring harness connector to solenoid.
5. Adjust idle mixture screws, turning screws in or out to obtain maximum idle RPM.
NOTE: On 2 and 4 barrel carburetors, adjust idle mixture screws equally.
6. Adjust idle speed to RPM specified for lean drop adjustment as in step 4.
7. Turn mixture adjusting screws clockwise (leaner) to obtain specified RPM drop. Engine should idle smoothly at specified curb idle speed.
NOTE: On 2 and 4 barrel carburetors, turn mixture screws in equally to obtain specified RPM drop.
8. Disconnect wiring harness connector to solenoid and adjust low idle speed to specifications:
a. On 2 and 4 barrel carburetors, turn throttle stop screw on carburetor.
b. On 1 barrel carburetors, turn 1/8 inch allen screw inside rear of solenoid.
9. Reconnect wire to solenoid and reconnect vacuum hoses to proper fittings. Install fuel filler cap on Corvette models.
Mar 23, 2019 at 12:40 PM
CJ MEDEVAC
  • 11,000 POSTS
So this is a "professionally" rebuilt carburetor on it now?
Are you competent with installing and correctly tuning the carburetor? (what I mean is, are you comfortable and have the tools/ meters to correctly perform the task?)
The Medic
Mar 23, 2019 at 12:47 PM
CJ MEDEVAC
  • 11,000 POSTS
Sorry J & N, I'm slow!
The Medic
Mar 23, 2019 at 12:48 PM
