rough running engine with unknown cause
120,000 MILES • V8 • 4WD • AUTOMATIC
ASHTERAH
The engine of the car runs rough and hesitates but not always. It has periods when it runs completely normal and then is back to running poorly. It will also just up and die suddenly but will immediately start back up again. We recently replaced the distributor rotor and the module and only noticed the issue about 1000 miles after that.
Jul 15, 2014 at 12:03 AM
HMAC300
  • 48,601 POSTS
see if you can move the rotor in the dist it should have very little movement, the gear on the dist may be worn out or wearing out. also scan for codes and check fuel pressure if TBI should be 9-11 psi autoparts rent the gauge
Jul 15, 2014 at 1:29 AM
