Rough running backfire
178,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DAVIDLWELLS
This SUV has me stumped. Bought it used had to make some repairs. Have changed motors in it. The old motor in it when was running rough sounded like wrist pin was knocking. Motor came out of 1997 pickup ran great. Since put motor in have replaced fuel pump temperature sensors all 4 O2 sensors. New spark plugs and wires. New distributor cap and rotor. Tried different PCM. When running rough will hardly idle when going up a hill have to pat the gas other wise will bog out it will not move.
Aug 14, 2020 at 10:07 PM
Good morning,
Are there any codes set?
Have you checked the compression on the donor motor to be sure there are no issues?
https://www.2carpros.com/articles/engine-has-low-power-output
Aug 15, 2020 at 12:05 AM
DAVIDLWELLS
Did not do compression test. Engine ran great when was in truck. 2 different engines in this SUV and both has this issue. Is it possible that wear on distributor can cause this issue? Can't say for sure which one was put back in it when done engine change.
Aug 15, 2020 at 1:28 AM
You need to do the compression test.
As far as the timing, do you have a timing light to give me the timing?
How did you set the timing?
Aug 15, 2020 at 8:55 AM
DAVIDLWELLS
This one sets with a scanner. It sets at zero. It has been set.
Aug 15, 2020 at 10:39 AM
Okay, did you check the fuel pressure to be sure the fuel pump is providing the correct amount of fuel?
That would be my next step. You can rent a tester at a parts store to verify the pressure.
Aug 15, 2020 at 9:42 PM
