Rough running
2001 CHRYSLER SEBRING
187,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
STRIPE
Warmed car up this morning, had to shut it off for a second. Started it back up and it was like it only running on half the cylinders.shut it off, tried again, but then revved it bout half to floor. RPM's shot up to 4. Gave it up until tonight, went out and tried it, it ran fine. Shut it off after about 2 minutes, tried again and it ran like crap. It didn't have time to warm up.also not sure what it is but finally discovered the burning smell and smoke source under the hood. Oil is leaking from under the block against the firewall. Not enough to use a lot. Have added 3/4 quart since oil change in July. Reading here, could be oil pressure sending unit. He has yet to take cover off and investigate.
Nov 15, 2019 at 10:16 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
This could be a problem with your vehicle's Idle Air Control [IAC] valve. Here is a link below explaining what is going on and how to fix it below:
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Nov 15, 2019 at 3:28 PM
STRIPE
Today he went out and the breather was totally off. Plus I now have a squirrel renting my car. He blew out the acorns, put breather back on so far so good. Except the oil leak I found have only added half quart since July or so. This was about 3 weeks ago, it was already down a half. That squirrel must be thirsty. Thank you and if it keeps doing it I will ask him to try the idle sensor.
Nov 15, 2019 at 11:31 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
That is what I was going to suggest next, to check to see if a squirrel had stored acorns in the air cleaner. LOL.
Thanks,
Alex
2CarPros
Nov 16, 2019 at 11:13 AM
STRIPE
I have cayenne pepper down below where I found pine cones, and yes I did get a bit of it in my eye, LOL it hurt. Plus I have ammonia bags all around the car. I did however, since I am an animal lover, go buy more acorns and stored them in the husbands motor. Don't want that poor thing to freeze.
Nov 16, 2019 at 1:04 PM
  • 55,402 POSTS
Good job, I am too, help whenever you can. Use 2CarPros anytime, we are here to help. Please tell a friend.
Nov 19, 2019 at 2:23 AM
SKI PIACZYNSKI
give it gas and it runs great fuel milage has reduced and the car is only sluggish as described. I have had since new and the car only uses synthetic oil Mobil 1
I have kept up with the tranny and the basics have never replaced the O2's but or the MAF. If you can help please advise.
Nov 19, 2019 at 2:23 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check engine on and or blinking
try to get the system scanned for codes
if any take care of it as it may be the issue
also I would check it for tune up and check ignition wires too
u have any codes let me know
I can try to translate them for you
good luck
ANTHONYLESLIE
Engine Performance problem
2001 Chrysler Sebring Automatic 130000 miles
When I leave for work in the mornings, my car runs just fine. As I drive around throughout the day, the car progressively runs rough. When I pull up to a stop light, sometimes the car idals down and sometimes shuts off. I have to restart it more and more the more i drive it during the day. When I come to a stop light and put the car in nutral, it usually stays running but the engin randumly reves up and then idals down....Any Idea what is causing this?
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
BUE1945
Coming home from work today, my 2001 Sebring started making a kind of humming sound when idling down while coming to a stop. A couple of times while stopped at a stop light, it began to idle very rough, so I would have to put it in neutral and step on the gas. Could this be a fuel pump going? Would like to know before it gets worse, as I need my car to get to work....
LEGITIMATE007
  • 5,121 POSTS
it could be, but check all fluids first of all and make sure everything is at a level that it should be, if you have a check engine light you should have it scanned, this service is usually free, autozone does it. your noise can be a pulley gone bad, a/c bearings could be going bad. but I cannot tell because I cannot see it. so yo may need it looked at, but as far as a check engine light, if it is on, then have it scanned and bring the codes back to me for further diagnosis
joe
Nov 19, 2019 at 2:24 AM (Merged)
