Rough running
180,000 MILES • 3.8L • V6 • FWD • AUTOMATIC
CHARLES RAY2
It will run fine until it gets worm. Then loss of power and runs rough. A constant miss that does not change. Has new coil pack, E3 plugs and wires. Started after I had to replace the pipe to the lower rad hoes. Runs strong until it get to op temp.
Feb 13, 2017 at 7:59 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak and scan for codes first then check fuel pressure with a gauge auto parts rent it see link.
Feb 13, 2017 at 10:09 PM
