Runs perfect one day and rough the next. Or not at all. Replaced MAF,IAC,TPS,PCV, temperature sending unit,computer,cleaned injectors and replaced rubber seals. Replaced spark plugs, coil pack and bad wires. Replaced throttle body. Checked all vacuum hoses for leaks.Checked fuel pressure at 30 psi.It has a new air filter. This is a different engine. The old engine ran rough to but had to replace because was damaged by water through the air intake.
Feb 24, 2020 at 7:22 AM
