Code p0215, rough idling?
104,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
JAMES HADDLE
Intermittent shuddering when idling or at a stop. Replaced intake manifold, intake solenoid, PCV valve. Checked all hoses. Shuddering got better after replacing the parts listed, but the issue hasn't completely gone away, neither has the check engine light. Error code p0215
Apr 11, 2025 at 4:10 AM
  • 55,746 POSTS
Is this a diesel engine?
P0215 - Engine Shutoff Solenoid Malfunction
If so, I would replace the fuel filter/water separator and then clear the codes. Please let us know what happens.
Apr 11, 2025 at 5:08 AM
JAMES HADDLE
gas/ethanol engine.
Apr 11, 2025 at 7:04 AM
  • 55,746 POSTS
Okay, I have seen the fuel pump control module have an issue and cause this code and it will make the engine idle rough, please go over this guide as well:
https://www.2carpros.com/articles/repairing-engine-rough-idle-issues
The control module is at the top of the fuel tank under the fuel pump access port. Clear the codes once completed. Check out the images (below).
Apr 13, 2025 at 2:36 AM
