Rough idling
154 MILES • 2.0L • 2WD • MANUAL
GENEREAL MPH PHONTICCA
  • 5 POSTS
Good Day. My car started having a rough idling. At first I thought it was the coils and the spark plugs but I eventually tested and checked them, none whatsoever. I cleaned the throttle body, checked vacuum leaks and nothing seems to solve the issue.
At high speed it drives well but when the rough idling kicks in, it goes into Limp Mode until it stops. Then I have to switch it off and start it again - the cycle continues for every three minutes or so.
I took out the fuel pump, checked connections and dirt, all is good. Please help.
Dec 4, 2018 at 4:17 PM
  • 110,248 POSTS
If the engine is going into limp mode, you really should have the computer scanned to determine what code is set. That will indicate where the problem is coming from.
Here is a quick video that shows how to use a scanner:
https://youtu.be/YV3TRZwer8k
Since the issue goes away when you turn the key off, I suspect it is a sensor issue.
Have it scanned and let me know what you find.
Dec 5, 2018 at 12:11 PM
  • 5 POSTS
Joe, thanks for your reply.
Quick update:
Found that the cable to the camshaft position sensor (connector) was corroded, fixed.
primed enough fuel and removed bubbles and car started. The result is that its idling rough, more like misfiring. I have cleared all the errors, but the camshaft fault seems to be coming back.
Another worrying factor is that when analyzing live data from obdeleven, on the 'Injector Status' channel, it seems as if the only responsive injector/cylinder when revving the car is Cylinder 2. The other three don't present any values at all. Please also note that the 'three' PD injectors installed have not been coded/adapted, not sure if this is the issue. But here's an attachment of the screenshot of the channel.
Any ideas would be greatly appreciated.
Nov 11, 2023 at 6:26 PM
  • 110,248 POSTS
That is odd. What is the actual code you are getting? Let me know. Also, let me know if once off idle if it seems to run okay.
joe
Nov 13, 2023 at 1:15 PM
  • 5 POSTS
Hi Joe, thanks very much.
What's really funny is that I'm not getting any injector fault codes after scanning several times. The only fault code that comes up even after clearing is the camshaft fault, which I will list below. This past weekend i have reconnected a wire that was corroded on the 3-pin connector. But generally, the only fault code I'm getting is the following:
01 Engine
System description: R4 2,0L EDC G000SG
Software number: 03G906016G
Software version: 9884
Hardware number: 0281011364
Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Trouble codes:
P3007 - Camshaft Position Sensor No signal
Intermittent
Nov 13, 2023 at 9:59 PM
  • 5 POSTS
I also attached a video I took when it was idling to shed some light. Sounds rough.
Nov 13, 2023 at 10:09 PM
  • 110,248 POSTS
I just realized the model year for this thread has to be different than your vehicle's model year.
Because of that, I need you to start a new thread that is for the correct year. We do this so it is more helpful to others. I hope you understand.
What I would like you to do is copy and paste everything you have indicated so far.
Here is the link to start a new post:
Let me know. And again, I hope you understand.
Nov 14, 2023 at 6:24 AM
