idles rough,.once goin down road,levels out,.happens often what is wrong?
Oct 13, 2014 at 4:42 AM
✓Experienced Mechanic
Have you replaced the fuel filter or had a tune up does recently?
Oct 13, 2014 at 12:19 PM
ZEIK1154
MEMBER
we changed,the mechanic did rather,the fuel filter,rotor,dist cap and the distributor itself....still not idling right....i was thinking,maybe,vaccum leak,
bad plug,or idle sensor........am i correct .............how can i check these mentioned.........thks for the help......steve b
Oct 14, 2014 at 4:35 AM
Hey Steve B
Hope all is well with you, a vacuum leak with certainly make the engine idle poorly.
Let me know what you find out :-) I am interested to see what happened.?
Oct 14, 2014 at 11:50 AM
ZEIK1154
MEMBER
hi.....the exterra selltled down,but,the check engine light came on....mechanic says tranny is the problem....the tranny guy says its electrical in tranny....what could this be now,,,,,thanks fr any help.....steve b
Jan 20, 2015 at 4:05 AM
Hey Steve b
How have you been? hope well, does the transmission work okay?
Best, Ken
Jan 20, 2015 at 4:24 AM
ZEIK1154
MEMBER
well.....thats the problem......tranny guy not sure what is wrong...he says its electrical.......how many electrical parts in that tranny can go wrong......is it that hard to figure out....been in shop a week now..............steve
Jan 20, 2015 at 10:17 PM
Hey Steve B,
There are a handful of shift solenoids and a couple switches and sensors, if the problem is outside of the garage's scope of expertise or the electrical problem will not presents itself, which is the problem which electrical issues, you have two choices, take it to another shop or just drive it until sometime else happens.
