rough idle when in gear not driving and loss of MPG?
176,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
DMBUIW
  • 6 POSTS
The truck idles rough when stopped and in gear. The truck has had the following recently replaced. All spark plugs, Mass Flow Value, EVAP Purge valve, and electric throttle body. All OEM parts. Have lost 3 to 4 MPG since all were replaced. Do I need to get the PCM flashed? Or ideas on what to do?
May 14, 2024 at 4:25 AM
  • 110,246 POSTS
A rough idle is usually caused by either a vacuum leak or a fuel pressure issue. Since you have dropped MPG, the first thing I suggest is checking for a vacuum leak as well as checking the fuel pump pressure. A faulty fuel pressure regulator can increase fuel pressure beyond the manufacture's specifications and force more fuel into the engine than wanted or needed.
On the other hand, an unmetered air leak will produce a lean fuel mixture causing the PCM to try to compensate by adding fuel to the engine.
Here are two links that explain how to check these two things:
Also, I attached the manufacturer's pressure specifications below. Try this and let me know what you find.
See pic below.
May 14, 2024 at 12:00 PM
DMBUIW
  • 6 POSTS
Thank you for the info and advice. I looked things over and did not find any vacuum leak and the fuel system pressure looked good it was in the correct range. It still seems sluggish when stepping on the gas (like it's taking a while to switch gears) and still has a shimmer while stopped and in gear.
May 20, 2024 at 1:15 AM
  • 110,246 POSTS
Thanks for the update. If it is in neutral, does it have a rough idle? As far as in gear, there is a load placed on the engine which causes it to torque one way or the other. I wonder if you may have a worn or faulty engine mount. If so, that can allow engine vibrations to be felt throughout the vehicle.
Take a look through this link. It explains what and how a mount works.
https://www.2carpros.com/articles/how-a-motor-mount-works
If possible, with the hood open, have a helper place the engine first in reverse and then drive. The engine will move a bit, but not too much. If you see more than an inch movement, this could be the problem at which point, we will need to inspect the mounts for damage.
May 20, 2024 at 11:35 AM
