Rough idle vibrations while accelerating
135,000 MILES • V6 • 2WD • AUTOMATIC
CORY SHANE
Truck was in park running fine then shut off randomly. Started it back up and it now idles low and has a descent amount of vibrations while idling and accelerating but not while coasting.
Dec 3, 2020 at 11:39 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I can think of 2 things the might be causing these troubles. First for the poor idling that could be caused by a faulty or dirty idle air control valve. Here are a few tutorials for you to view about this:
https://www.2carpros.com/articles/idle-air-control-valve-service
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
The second issue for poor acceleration might be a weak or failing fuel pump not supplying sufficient fuel pressure. Here is a tutorial for testing fuel pressure:
The proper fuel pressure for your vehicle should be key on - engine off between 50-57 PSI. Hope this helps and thanks for using 2CarPros.
Dec 4, 2020 at 8:11 AM
