rough idle then shuts off?
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHAD BUTLER
my car listed above starts, idles rough sounds like a lawn mower then shuts off after 5 minutes of running. it'll start again and do the same. had it scanned, and they said something about the PCM.
Jan 1, 2025 at 2:42 PM
  • 55,694 POSTS
If it is idling rough, you can have low compression in one or more cylinders, this guide can help us go over what is happening and why. Also, it would be good if you could give us the codes numbers, which should help us as well.
https://www.2carpros.com/articles/repairing-engine-rough-idle-issues
And this guide can help us get the code numbers:
Please go over these guides and get back to us.
Jan 2, 2025 at 3:07 AM
