Rough idle, stalls and or falls flat on face while moving
245,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
VICTORBULLOCK
I changed the plugs and coil packs. It got better for like three days then started again. When you are trying to get going it acts like it loads up and wont take the gas unless you force it to then it bogs for a few seconds then takes off.
Jun 17, 2020 at 7:49 PM
Good morning,
I would check the fuel pressure to be sure there is enough fuel at the injectors.
Is the check engine light on?
https://www.2carpros.com/articles/engine-has-low-power-output
I would also have the cat converters checked to be sure they are not blocked not allowing the engine to breathe.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Lastly would be timing. check the compression to see if the timing chain is slacked causing retarded timing.
Jun 17, 2020 at 9:42 PM
