Rough idle, smells of gas, blowing smoke (white from exhaust) and very little power?
270,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
SHARRON MCINTOSH
Had the fuel injectors replaced. I was told that was the problem, about 3 months ago. The mechanic also said that the head was blown, which it is not. But it started doing the same thing again a few days ago.
Crankshaft hose needs replaced also but cannot find the right one. The dealer tells me it's discontinued.
Jun 22, 2023 at 5:08 AM
  • 110,245 POSTS
Are you getting a lot of white smoke from the exhaust? If so, check to make sure the engine coolant is getting low. When coolant enters the combustion chamber, it burns white. It is possible you do have a failed head gasket.
Do me a favor. Take a look at this link, see if anything mirrors what you experience:
https://www.2carpros.com/articles/recognizing-the-symptoms-understanding-a-blown-head-gasket-in-your-vehicle
Also, I'm not sure what a crankshaft hose is. Can you explain?
Jun 22, 2023 at 3:11 PM
SHARRON MCINTOSH
It's the hose on top in this picture. Could also be called PCV hose?
Jun 23, 2023 at 1:41 AM
  • 110,245 POSTS
Yep, that's the PCV hose. LOL You lost me with the crankshaft hose. Were you able to review the link I attached above?
Jun 23, 2023 at 1:25 PM
