Running poor at an idle a loping idle to try to clarify, steady putt putt putt, big hesitation off the line as if I am not even hitting the throttle but then catches and gets moving then when at a cruise speed and lightly push throttle getting a stuttering like a vibration. Let up slightly or throttle harder will stop. Also hesitation when powering out of a slow corner (turning onto a different street.) No CEL (check engine light) .
Was CEL when issue suddenly occurred. Random misfire (P0300)misfire number two cylinder (P0302). Changed out all 6 coils and plugs cleared codes. Ran the same but after short drive threw P0159 code. Bad O2: sensor. Changed both inboard O2 sensors. Cleared codes. Ran a bit better but not much change. Out for another test drive ran basically the same. Now no codes what so ever. Fuel delivery system checks out fine. Just cannot figure this out. Help please.
Aug 19, 2018 at 6:06 AM
