Intermittent rough idle/no start
1997 HONDA CIVIC
172,000 MILES • 4 CYL • 2WD • AUTOMATIC
HONDAMIKE
  • CERTIFIED EXPERT
  • 71 POSTS
After being warm, car would not start. Acted like it was flooded. Held down the throttle, it sputtered to life and started running.
It happened again and thought since it was hot outside, the igniter was going... so I replaced it.
Test drive, all okay...
Next time, hard start again...
Rough idle...
I removed the vacuum line to the fuel regulator and it runs great! Which is weird because a vacuum leak usually makes an engine run rough?
Do I have a bad fuel regulator?
Thanks!
Jul 12, 2021 at 5:00 PM
  • CERTIFIED EXPERT
Good morning,
When you removed the hose, you raised the fuel pressure. By doing that, the engine runs better.
This sounds like you have a bad fuel pump not producing the correct pressure. You need to test the pressure to confirm. You can rent a tester from a parts store.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jul 13, 2021 at 4:02 AM
HONDAMIKE
  • CERTIFIED EXPERT
  • 71 POSTS
Thank you. I will do that.
Jul 13, 2021 at 6:52 AM
  • CERTIFIED EXPERT
You are welcome.
Always glad to help.
Jul 14, 2021 at 3:35 PM
