Having a rough idle issue for several months now. Replaced spark plugs (NGK iridium ix), wires (8 mm Taylor), distributor assembly, coil, EGR valve (vacuumed most of the carbon after removing the original EGR valve), o2 sensor. Also, bought original second hand parts from eBay (map sensor, IACV, throttle body). Cleaned the throttle body and checked the throttle position sensor - voltages are okay. Installed all these parts along those many months of having the idle problem. Installed the throttle body, IACV, map sensor. Bleed the coolant. Disconnected the IACV wire to adjust the base idle (750 rpm). Reset ECU. Adjusted the timing. The car runs fine and has fast acceleration with minimal hesitation. If i am on stop light the car idles rough when the rpm goes down below 1000. Rough idle increases if A/C was turned on. Rpm dips down to around 500 then goes back up to 750-800 rpm. I think it is an electrical issue. but i cannot pinpoint where the problem is. Had Autozone checked my alternator, battery and both are fine. The rough idle stops when rpm is 1000 and above. Failed emission recently (HC was high) that is why i replaced the o2 sensor, EGR valve, spark plugs and wires. But the rough idle is still the main problem. Been searching the internet for the solution but with no luck. Hope you can help! Thanks!
Sep 28, 2017 at 3:08 PM
