Rough idle, misfire, hissing noise, vacuum leak
140,000 MILES • 3.5L • V6 • AUTOMATIC
BRYTONDANIEL
When I start my car it goes into a rough idle that shakes the entire car, as i am driving i can feel misfires and a hissing noise. i have been told that i may have a vacuum leak or that i need to replace the entire intake.
Jul 3, 2017 at 10:00 AM
  • 31,937 POSTS
Very much sounds like a vacuum leak. there are a few ways to check, with the engine idling, spray some brake clean around the manifold, if the revs pick up you have a vacuum leak, or you can use a smoke machine, this will pinpoint the exact point of the leak as you will see the smoke coming from the leak it self.
Jul 3, 2017 at 8:25 PM
