Rough idle, lost power, and it misses while driving?
147,000 MILES • 1.8L • 4 CYL • AUTOMATIC
LUCAS POSAS
Check engine light came on I changed the oxygen sensors front and back, the Mas flow sensor, and the valve cover gasket and the problem remains, help.
Aug 16, 2023 at 1:19 PM
  • 110,251 POSTS
If the check engine light is flashing, that indicates a misfire. I realize you replaced the valve cover gasket and other sensors. However, the problem could be related to a coil, a spark plug, compression issues, and so on. If you replaced the valve cover, was there oil in the spark plug wells? If so, did you inspect the rubber boots on the coils to make sure they are not damaged? Also, if there was enough oil to cause a problem, it may have damaged the coil pack.
What are the codes you retrieved when the computer was scanned? Also, if I recall, the ignition coils are part of the module. See pic below. Let me know if that is correct.
See pic below.
Aug 16, 2023 at 3:58 PM
LUCAS POSAS
Yes, it turned out I had to replace the valve it was stuck open. thanks guys
Aug 23, 2023 at 2:07 PM
  • 110,251 POSTS
Thanks for the update. What valve did you replace? I'm hoping it was something simple.
Regardless, I'm glad you got it taken care of. Feel free to come back anytime in the future.
Aug 24, 2023 at 12:28 PM
