Hello, this is a new to me project vehicle that I bought with the expectation of it needing work, but it seems like every day there is something else going wrong! The latest malfunctions is as follows: It was a pretty cold day, around 15-20 oF, so I let it warm up for about 5 minutes. Then I could hear the car’s engine speed dropping and struggle to not stall out, then it would wake itself up and the rpm's would bounce back to a normal range (judging by the sounds of it) so I hopped in and took it around the block. Noticed severe drop in power and super rough idle. Could barely get it back to my house even on level streets. My engine light is on (has been, I thought I fixed it but it came back) I’m getting p0455, with is the same code I was getting before noticing these problems. I feel this may be unrelated to my current issue. Also, not sure if I ran the car long enough for it to trigger any other error codes. Some other probably unrelated issues; the switch for the headlights randomly fails, and sometimes the speedometer and tachometer will drop to 0 while driving, then come back, and the airbag light will also randomly pop on. Only mention these just on the off chance that a professional might see a correlation where my untrained eye had figured they are unrelated. Thanks!
Jan 19, 2020 at 7:22 AM
