Rough idle, loss of power
230 MILES • 3.0L • V6 • 2WD • AUTOMATIC
0R1GAM1_OWL
Hey everyone, I have been working on this truck I got for a few weeks now. I am not sure if it is a vacuum leak or something else. it will start fine, it idles rough as heck, and will drive okay but there is no get up, and after running a while the rpm's drop, it starts shuttering and shaking and the check engine light comes on. I have done the following:
Full tune up
Air filter
Fuel filter
Crankshaft position sensor
Cleaned the MAF sensor well
Any help or ideas would be much appreciated. Thanks in advance!
Apr 4, 2019 at 10:53 PM
Good morning,
I would start with a compression test to be sure there is no internal engine damage.
Apr 4, 2019 at 11:33 PM
0R1GAM1_OWL
I will look into that. Thanks!
Apr 4, 2019 at 11:37 PM
You are welcome.
Keep us updated.
Apr 4, 2019 at 11:38 PM
0R1GAM1_OWL
Roy, I just wanted to let you know that I was told that the ignition coil had a dead spot. Replaced that and it runs way better. Still has no power but it's a 2003 with 259,000 miles I don't expect it to be a race car haha. Thank you for the advice!
Apr 11, 2019 at 8:30 AM
You are welcome.
Always glad to help.
Apr 11, 2019 at 8:38 AM
