Rough Idle and engine stalling when idle
160,000 MILES • 4.6L • 4 CYL • 2WD • AUTOMATIC
D7MILAN
A couple of weeks ago my check engine light came on and I swapped out a few sensors with no success. I've noticed the car having a rough idle, where the RPM's isn't stable and drops suddenly then rises up again. Every couple of days it would also suddenly stall when i'm stopped.
Sep 7, 2020 at 9:00 PM
Good morning,
Can I have the code or codes that were set in the system and the sensors you replaced?
I would start by cleaning the throttle body of all carbon as that is a very common issue for stalling.
https://www.2carpros.com/articles/stall-at-idle
Sep 7, 2020 at 9:27 PM
