Rough idle and engine shaking?
94,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
LUKEMANGO
  • 10 POSTS
The car idles rough and the engine shakes, I have a video of it occurring attached. My bets are either the EGR valve or engine mounts, but any advice is appreciated.
Video if attached doesn't work: https://streamable.com/p2yk82
Aug 11, 2023 at 7:41 PM
  • 55,740 POSTS
Thanks for the video. it looks like the engine mounts need to be replaced. The engine sounds like it is running okay. Does the engine smooth out when just above idle? If so, the mounts are bad.
Aug 12, 2023 at 8:32 AM
LUKEMANGO
  • 10 POSTS
yes, the engine runs fine when not in idle.
Aug 12, 2023 at 9:16 AM
  • 55,740 POSTS
Yep, the engine mounts are worn out. it happens. I have asked our Euro expert to chime in with engine mount replacement instructions.
Aug 14, 2023 at 4:12 AM
LUKEMANGO
  • 10 POSTS
much appreciated, took it to a garage today and they confirmed it was the lower engine mount (gearbox stabilizer), will look to rectify soon.
Aug 14, 2023 at 7:58 AM
BORIS K
  • 836 POSTS
The gearbox stabilizer is called a pendulum support. See image 2
It is mounted into a recess in the subframe and attached with 2 bolts on the lower transmission housing, see image 1.
When replacing the support, you will need to replace the 3 bolts too.
The 2 bolts at the transmission side are tightened to 30Nm + 90 degree.
The bolt at the subframe is tightened to 40Nm + 90 degree.
It is a fairly simple install as the transmission will not drop when loosening the mounting.
Suggest to first remove the 2 transmission side bolts.
Next loosen and remove the bolt at the subframe.
The mounting is quite tight in the recess, you will need to wiggle it out using a small pry bar or large flat screwdriver. Fit new mounting into the subframe recess first.
Install new bolts and tighten to correct torque using a torque wrench and angle attachment.
See image 3 for angle attachment.
Cheers, Boris
Aug 14, 2023 at 5:52 PM
LUKEMANGO
  • 10 POSTS
thank you. I will let you know how i get on.
Aug 14, 2023 at 10:47 PM
  • 55,740 POSTS
Please do!
Aug 15, 2023 at 1:43 AM
LUKEMANGO
  • 10 POSTS
Well, that didn't work, still occurring, video attached.
Aug 17, 2023 at 10:31 PM
  • 55,740 POSTS
Hmm, you may have low compression in one of the cylinders. Let's see what Boris says when he sees the video.
Aug 19, 2023 at 1:58 AM
LUKEMANGO
  • 10 POSTS
sounds good.
Aug 21, 2023 at 6:47 AM
BORIS K
  • 836 POSTS
The video certainly seems to show a misfire, but not constant
Being a diesel engine my first check would be a possible diesel injector issue.
Do you have access to a suitable diagnostic tool to check injector compensating values?
See image below
VCDS/VAG-COM would be the best tool for VW based products
A lot for sale online, diagnostic cable and software. You will require your own laptop computer.
Also check if you have any possible fault codes.
Carry out a CAN scan using a suitable diagnostic tool:
A good video showing the 1.6 diesel engine:
https://youtu.be/RmbN936pXQ8
Cheers, Boris
Aug 21, 2023 at 7:48 PM
LUKEMANGO
  • 10 POSTS
I've got an OBD2 scanner that connects via Bluetooth to my phone, there's no fault codes showing up, although when the mass air flow rate spikes are when the engine shakes. graph below.
Aug 21, 2023 at 8:35 PM
LUKEMANGO
  • 10 POSTS
The app that I'm using is https://www.obdsoftware.net/software/obdfusion for reference.
Aug 21, 2023 at 8:37 PM
LUKEMANGO
  • 10 POSTS
I should also mention that 2 days ago I took out the airbox and used some air flow sensor cleaner on the MAF.
Aug 21, 2023 at 9:03 PM
  • 55,740 POSTS
Opps, the reading from the MAF sensor means you have a leaky intake valve. To confirm the issue, we can do a compression test, this guide should help:
Please go over this guide and get back to us.
Aug 24, 2023 at 3:00 AM
LUKEMANGO
  • 10 POSTS
hi, I thought i'd update you as i took it to the SEAT dealership - it turned out to be an ECU software update that fixed it of all things, quite the goose chase in the end but we got there.
Nov 5, 2023 at 9:42 AM
  • 55,740 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Nov 6, 2023 at 12:31 AM
