Rough idle engine check light on
33,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
DOUGLAS G
Check engine light comes on after it has been driven a while and it idles rough and most times will shut off.
Dec 11, 2019 at 4:08 AM
SCGRANTURISMO
  • 4,897 POSTS
Can you please pull the Direct Trouble Code [DTC] for us with a code reader from your vehicle's Data Link Connector[DLC]. If you are unsure how to do this, then here is a link to a guide explaining how to do it below:
Please get back to us with the DTC[s] and we will go from there.
Thanks,
Alex
2CarPros
Dec 11, 2019 at 4:54 AM
