rough idle (does not stall, steady @700-750rpm)...unnusual smell in exhaust pipe
2007 TOYOTA COROLLA
110,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
HUMMINGBIRD3
i already clean all hose,throttle,iac valve,map sensor,vacuum solenoid valve,spark plugs is only 9 months,oil is due come 500km more.. i noticed idle is somewhat missing power..but it does not stall.. it hesitate in irst gear 3rd and 4th i can race the engine power is acceptable..irst gear..when you are in a ramp you need to rev egngine or you stall.. exhaust sound is dut dut dut dut.. per ect (letter '' '' is not '' ''untcnioning in my keyboard see?) idle sounds like a continuous rhythm drrrrrttt.. i suspect the o2 sensor is bad or the ecm module need to be scan? (i just reset the ecm nothing works..pls advice me what to do this is my only car and can't aord a new one or a good secondhand Honda civics
Jul 23, 2014 at 12:32 PM
  • 110,244 POSTS
Is the check engine light on? Have you checked to make sure the catalytic converter isn't plugging? Also, do you get a rotten egg smell from the exhaust?
Jul 23, 2014 at 12:45 PM
HUMMINGBIRD3
car is barely 6 yr old..no engine light on..unless its shorted..ecm receives signal whether wrong or not ..its like garbage in garbage out..gas rom exhaust smells like chemical.. i think its the oil additive i put in the engine..(250ml)
Jul 23, 2014 at 2:02 PM
  • 110,244 POSTS
Check the converter to see if it is getting red hot. Also, what kind of additive did you use?
Jul 24, 2014 at 11:04 AM
